- The following notification is received every hour:
Message:
/etc/cron.hourly/asl:
Error: ASL has not been configured
run-parts: /etc/cron.hourly/asl exited with return code 1
EMAIL ERROR - 2 - Manual execution of the task results in the same outcome:
# run-parts /etc/cron.hourly/
/etc/cron.hourly/asl:Error: ASL has not been configured
- Executing
aum -c
via SSH results in another error:# aum -c
Errors were encountered:L CODE SOURCE MESSAGE
4 9998 Core::_get_config New key, updating config
2 2 ASLConfig::config_update An error occurred attempting to read file /etc/asl/config
3 9998 Core::_get_config Failed to update configuration
4 9998 Core::app_exit Exiting with error level 3
/etc/asl/config
file is empty (1 byte size):# ls -l /etc/asl/config
-rw——-. 1 tortix root 1 Aug 31 04:11 /etc/asl/config
Aum was updated, but was not configured properly, or /etc/asl/config
file is empty.
Note: in case you have access to the server via SSH, check the solution from the spoiler below first. Restoring the configuration from the backup overall is a faster way in case there is a backup.
At first, try switching ModSecurity Rule Set back and forth. For that:
- Log in to Plesk.
- Navigate to Tools & Settings >Â Web Application Firewall (ModSecurity) > Settings.
- Temporary select any other Rule Set, for example, OWASP ModSecurity, and click ‘Apply‘.
- Select Atomic Basic ModSecurity back and click ‘Apply‘.
Those actions should re-create the empty /etc/asl/config
file.
In case it did not help, try restoring /etc/asl/config
from the backup.
Click here to reveal additional information. SSH access is required in order to proceed.
- Log in to the server via SSH.
- List all the configs of asl, there should be a previous version of this file listed, for example:
# ls -lt /etc/asl/config*
-rw——-. 1 tortix root 13032 Jun 30 10:09 /etc/asl/config.rpmnew
-rw——-. 1 tortix root 13311 Jun 29 06:00 config.##### - Remove empty /etc/asl/config:
# rm -f /etc/asl/config
- Use the most recent backup of the file found on step 2 to restore it:
# cp -a /etc/asl/config.rpmnew /etc/asl/config
- Try to configure aum:
# aum -c
- Verify that the issue is gone by executing the task manually (it may take a while; in case there is no error from the notification right after the start of the command below, then it works):
